1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 4 New Guy | | New Guy Joined: Jan 2016 Posts: 4 | Would like to change my 4 speed stick to an automatic, because of disability. I can operate the gas pedal and brake but not the clutch. Is this possible on a C60 with a 292 six? Thank you | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | "possible" sure. One of the first questions is what do you do with your truck. Running empty is a lot different than loaded down and weighing in at 20,000 pounds. Are you running around town, or going down the freeway for long distances, and are you driving on fairly flat terrain, or pulling big hills?
I am not familiar with putting an auto in the larger trucks but I am sure someone else will chime in soon. They will be asking the questions above though. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Would be easy to put a TH400 in it. Find one out of motor home that has the driveshaft brake on the back.
1950 4100 - unrestored and driven weekly for almost no reason at all.
