4 members (Otto Skorzeny, dt235sd, Peggy M, klhansen), 85 guests, and 3 robots.
Topics128,088
Posts1,056,390
Members48,442
Hello all: I have a small problem with the parking (emergency) brake on my '53.
The pedal won't stay down (engaged) when I try to set the parking brake on my truck. I've tried modifying the angle on the lock bar but that doesn't seem to help (just scrapes the paint off the connector bar). Shoe adjustment seems OK as well.
Any ideas or suggestions greatly appreciated. Thanks!
1953 Chevrolet 3104 1/2-Ton
More pix
Do you have the spring which goes between the lock bar and the parking brake bracket (which is located on the outside of the toe board)?
So is 5.497 the part number for any old spring? Both the one on the pedal and the one on the release rod are the same number. They obviously aren't the same size. headscratch
Carl: Thanks for the suggestion. I do have the spring in place. It looks like I may have to keep working with the shape and bend on the lock bar.
More pix
That would be: 4.597 dang
4.597 is the Group Number for "SPRING, Parking Brake". The specific springs are then listed in that Group. shake
Before you alter the lock bar, remove the release rod from it and see if it holds the pedal in the locked position. Sometimes the rod gets bent or installed incorrectly, preventing the lever from locking the pedal into place.
Carl
Carl
Carl: Thanks (again) for this suggestion. I tried separating the lock bar, but it did not make any difference. I'll keep after it, and if I am able to fix it, I'll share the secret of my success.
More pix
One quick question. Is there any interference between the lock lever and the floor mat? I have had issue with just the slightest contact of either the floor mat or the padding underneath the mat. Those lock bars can be finicky.
I strongly urge you not to alter the lock bar in any way. Hopefully someone who had the truck before you didn't alter it, causing you the difficulties you are having.
You can try removing the paint from the curved, round pedal rod to allow the locking bar to have a better bite upon it. The force which makes this apparatus work is friction between those 2 parts.
Carl
This is an old subject, but I thought I would post how I solved the problem.
Evidently, when I was working under the dash at some point, I managed to hit the small L-shaped bracket thru which the parking brake release rod goes (probably, with my head). I managed to bend one leg of the bracket enough so that it exerted just a little tension on the back side of the release handle. Just enough tension, it turns out, to prevent the brake from engaging.
Straightened the bracket, so that 1/4" of play remained between the bracket and the handle (like the manual says), and all good now.
More pix
