8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Got a chance to use my boom today to move the cab out of the way while I work on the frame/suspension. Jerry told me about the 4x4 in the door and I used a ratchet strap to keep it in the door frame. Boom
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | That looks like it worked pretty slick. You obviously used a strap that was stout enough. Shallow angles like that put a lot of tension on the strap.
Coming in from the front like that as opposed to the engine hoist with beam method I've seen posed on here looks like it might work better just from the access standpoint. Of course if there's enough room to roll the chassis, then the engine hoist method would work fine. Where my truck is sitting, I wouldn't be able to move an engine stand on the gravel. It'd be roll the chassis forward, lift the cab, roll the chassis back, and roll a trailer under the cab to move it. It's going to be an exercise in any case.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | For heavy lifts (an engine) I use a chain and tensioner back to the bucket. This was a HD strap through a smooth/large chain loop. Really pleased how it worked.
That 4x4 (beam) has a small pcs of chain underneath in the center that I use to lift the cab off the frame with an engine hoist. The small piece of chain keeps the hoist from slipping off the beam. That also works well and give more control.
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The boom for my tractor attaches to the 3-point hitch and can extend out to 10 feet or so with one piece of pipe that telescopes over a slightly smaller one. I've used it to move a complete Bridgeport mill around a couple of times, so an engine, a frame, or the front end of a car doesn't present much of a problem. Of course, the 1,000 LBS of suitcase weights on the front bumper helps keep the steer axle on the ground! The tractor is a Massey-Ferguson 180. Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Instant forklift. Nice Paul
Jerry, I've seen guys put up 50' wide trusses on a pole barn with a 3 pt. boom like yours. Much more lift power than with my bucket, but I have a lot of fine tuning control with all the bucket movements.
