Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Peggy M, 52Carl, Gdads51), 600 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
I am trying to figure out the routing of the heater hoses. The issue is the clamping of the hoses to the RH inner fender. There are two small raised ribs on the inner fender about 1 ½” long and 1/8” wide. Both are vertical. My guess is that the double-hose clamp is next to the upper one for six-cylinder engines because the voltage regulator is on the firewall and, therefore, not in the way of the clamp and hoses. In contrast, for trucks with the eight-cylinder engine I suspect the clamp goes next to the lower rib because the hoses would have to go around the VR because the VR is about 2” forward of the upper rib.
Just wondering if you ever got a reply to this old post? I'm looking for the heater hose routing diagram. Hand drawn or OEM schematic. Can't find one. I just finished rebuilded heater box and ready to install system.
fly4,
Can you take and post a picture of your installed heater box and hose connection, as well as the inner fender area where "dimples" mentioned by member "Gates" are in the original post?
I don't have a GMC book/diagram, but do have a 1957 Chevrolet Accessories Installation Reference Manual with diagrams and descriptions of the hose install that might be of use to answer your question.
Need your pictures to try and make sure what I provide is relevant. wink
Dan
~ Dan
1951 Chevy 3 window 3100
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.037s Queries: 14 (0.035s) Memory: 0.5975 MB (Peak: 0.6336 MB) Data Comp: Zlib Server Time: 2025-09-21 23:09:22 UTC
Valid HTML 5 and Valid CSS
