| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | I guess you didn't see this thread from about 3 weeks ago: Daytona Carb
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I did not see it.
Thank you very much for the link to the thread. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | Went to Daytona Parts CO yesterday and spoke with the owner. I wasn't able to take any notes but if I got everything correctly the universal carb he sells is manufacturer in Argentina by a CO that's been in business for many years making carbs for Chevy & fords . Anyway their universal carb is a redesigned Holly carb with improved features to correct any short commings from the original. They are brand new and actively manufactured. The Chevy replacement carb is basically a copy of the zenith 28. The Chevy replacement carb is is currently under a design change to add a high speed adjustable jet as on the universal carb. The owner is very knowledgeable and very helpfull. Either one or these carbs maybe the way to go. Currently he is recommending the universal carb for dual carb applications. He spent a good 45 minutes with me explaining his carbs and his operation. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | IMHO a plain tube fixed venturi carburetor can't really be universal, there are too many variables in the engine design especially engine vacuum and A/F mixture curve. The closest you're going to get is a constant vacuum type like the S.U., Mikuni, Keihin, etc. CV, Stromberg CD, etc., but none of which were available in down draft configuration that I know of. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The carb is a Holley 1904 clone. I think used on Fords. People do like it.
If there was ever a place that would promote using original reusable parts, rejuvenating them, rebuilding them, reusing them, it's this Stovebolt place.
I think it's enjoyable to find a carb and rebuild it and see it run.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The Holley 1904 was prone to warpage of the main casting and the bowl, similar to the Rochester B. Since the bowl mounts vertically on to the main body on the 1904, warpage causes a fuel leak at the bottom of the bowl.
The earliest 1904's had the problem, but it took longer as the bowl was glass, which didn't warp. When the glass bowls were replaced with die-cast bowls approximately 1959 or so, the problem got worse, as the die-cast bowls also warped.
Hope the clone addressed this issue.
Some 30 or so years ago, the 1904 with the glass bowl was popular with inline 6 hot rodders and multiple carbs, as one could actually see the fuel run into the bowl and the float operate. Because of the leakage, less popular today.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I saw one of those glass bowl carbs at a show last yr. I believe it was on a Rambler 6 banger. Wondered about it since. Good info carbking. | | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | Yes they did if you look at the bowl it has gussets along the perimeter to prevent that problem from happening | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | I am curious why they picked this particular model to reproduce??? The Holley 1904 is available in two different flange sizes (like the Rochester B) and several different internal venturi sizes for use on engines from 144 to 305 CID; and used ones (except the ones for the 144) are much more common than even the Rochester B. We have way more than 100; and I never really tried to buy them, just got them in large purchases of other carbs. And even the warpage is much easier to straighten than the Rochester, as there are no projections on the surface to straighten. Just my curiousity  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Found the pics I took of that glass bowled carb. Pic 1 Pic 2 | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | From the description: "for 200-300 CID 6 cylinder applications"
How odd. Chevrolet used 8 different Rochester Model B carburetor sizes just for the 216" through 292" engines. I guess they were wrong. | | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | One of the design changes was elongating the mounting holes so it can fit 2-11/16 or 2-15/16 intake stud spacing. They also have adjustable linkage | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Slotting the throttle body mounting holes only increase the number of manifold on which the carburetor may be mounted; NOT the different displacements on which a carburetor may be used efficiently. The internal main venturi diameter places limits on efficient use. We have advocated for years when migrating ONE carburetor for one engine to another STREET ENGINE that, FOR BEST RESULTS, the "donor" engine should be +- (plus or minus) 3 percent in displacement from the "donee" engine. As example, Chevrolet made a 235 CID. 3 percent of 235 is approximately 7; so for best results, a single carburetor from other engines of displacement of 228 to 242 should be used. Can this "rule of thumb" be ignored? Certainly, but results may not be totally desirable on the street. Example: we used to sponsor a 4 cylinder race team with a 2.0 liter (121 CID) engine from that company whose name is the same as the last name of Tennessee Ernie. For racing purposes, we installed a four-barrel from a 283 Chevy. Above 5000 RPM it ran great. Would NOT idle at 2000 RPM! Both Carter and Zenith produced "universal" carbs in the 1930's with slotted throttle bodies. After WWII, both ceased this practice, and produced a wider range of "universals" with different internal venturii. And for O.E. applications, many more (check out Panic's post two above this one) were produced. Stromberg, to my knowledge, did not slot the throttle bodies. The link below, while it is for updraft carbs, not downdraft, may explain the "sizing" criteria better: http://www.thecarburetorshop.com/Stromberg_SF_carburetors.htmWhen choosing a carburetor (or anything else) don't discount the five (or 6, depending on language skills) "P"'s of Engineering. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2016 Posts: 11 New Guy | | New Guy Joined: Oct 2016 Posts: 11 | Regarding the Daytona Universal carb: any updates on it? Anyone using it? I'm weighing the pros and cons of replacing my Rochester B. Thanks. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Pro: Carter YF Con: Rochester B Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Which model/models Carter YF? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 |
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any/all of these? 756s — 216 engine aftermarket 1937~1952 787s — 216 engine aftermarket 1937~1952 788s — 235 engine aftermarket 1950~1952 789s — 235 engine aftermarket 1950~1952 890s — 235 engine aftermarket manual choke (number assigned, no production) 891s — 235 engine aftermarket auto choke (number assigned, no production) 964s — 216 engine aftermarket manual choke 1937~1952 965s — 216 engine aftermarket auto choke 1937~1952 966s — 235 engine aftermarket manual choke 1950~1952 967s — 235 engine aftermarket auto choke 1950~1952 2008s — 216 engine aftermarket 1937~1952 2046s — 206 engine aftermarket 1932~1936 2100s — 235 engine aftermarket manual choke 1953~1956 2101s — 235 engine aftermarket auto choke 1953~1956 2104s — 261 engine aftermarket (number assigned, no production) 3055s — aftermarket (number assigned, no production) 3211s — 235 engine aftermarket 1957~1962
What mounting bolt-to-bolt distance for each model (or, for what years)? Does that change in 1953? | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Just a guess: All 216 and early 235 are SAE #2 flange: 2-11/16" 235 Powerglide, late, and all 261 are SAE #3 flange: 2-15/16"
w/r/t Daytona Universal carb: pass it by | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Carter pretty well designed these to be a bolt-on swap.
Linkage, fuel lines, air cleaners, everything would pretty much bolt up.
Panic is correct about the size 2 and size 3 flanges.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
