0 members (),
209
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 11 New Guy | | New Guy Joined: Jun 2016 Posts: 11 | Plan, Rearend swap to GM 14 bolt FF,3.73, rear disc brake swap, also front disc brake swap keep I-beam, SB 350 I'll build, to a NV4500 5spd trans, Wife wants to keep it manual for nostalgia. Well thats the plan if Wyoming weather permits! I'll start tear down after snows gone (no shop). | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Don't know your situation but I'd start with building a shop of some sort. Worked in your part of the world several times (outside) and as I'm from the South would not undertake your task without shelter, lights, power, etc. Anyway, good luck with your build.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I got a tent like thing from Costco, 10 x 20, so I can keep the snow off, use great solar heater in sky on workdays, facing south to take advantage of low winter sun angle, windbreak; I used to live in Laramie, so I know what you are talking about. Good luck.
Ed
| | | | | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | I lived in Laramie, too. The snow doesn't melt there, it just blows around until it wears out. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
