0 members (), 209 guests, and 3 robots.
Topics128,266
Posts1,058,368
Members48,485
#1202488 02/01/2017 9:16 AM
Plan, Rearend swap to GM 14 bolt FF,3.73, rear disc brake swap, also front disc brake swap keep I-beam, SB 350 I'll build, to a NV4500 5spd trans, Wife wants to keep it manual for nostalgia. Well thats the plan if Wyoming weather permits! I'll start tear down after snows gone (no shop).
Don't know your situation but I'd start with building a shop of some sort. Worked in your part of the world several times (outside) and as I'm from the South would not undertake your task without shelter, lights, power, etc. Anyway, good luck with your build.
Crusing in the Passing Lane
I got a tent like thing from Costco, 10 x 20, so I can keep the snow off, use great solar heater in sky on workdays, facing south to take advantage of low winter sun angle, windbreak; I used to live in Laramie, so I know what you are talking about. Good luck.
Ed
I lived in Laramie, too. The snow doesn't melt there, it just blows around until it wears out.
