0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#1202391 01/31/2017 7:15 PM
My '59 came to me with an elec. wiper motor, but that motor has failed. The motors I see from vendors all say "for conversion from original vacuum motor."
Did they put a factory elec. in any of the '59 1/2 tons or were they all vacuum? If so, I've got a conversion that's failed.
The pic I see on the American Classic site has both link arms mounting on the same side of the motor while mine has one on top and the other on the bottom.
I'm obviously concerned about fitment. Anyone been through this or have knowledge on what will/won't work?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
See if you can find a part number or other identifiable info. Then google it, or check ebay ect.
Another quality post.
Real Trucks Rattle
There was a factory electric wiper motor available for the task force trucks. I know the 56 is different from the 58/59, so like many other differences, the 55.2-57 were likely one way and the 58-59 another. The 56, what I have, has a little mechanical cable that runs from the knob to the switch on the motor assembly and the later ones have a remote electrical switch, IIRC. Both systems show up from time to time on eBay.
55.2-57 wiper motor looks like this and has a mechanical switch connection as Tom sez .... the 58-59 motor looks like this and has an electrical switch like this, and unique drive arms
the 2 motors are not interchangeable because the link arms are quite different, the early one uses the same arms as a vacuum style - if you have an original 59 electric setup you need to find an original motor or the vacuum arms to mate with a repro motor
Thank you, Bill. The pictures were very helpful and show I have an original 59 elec. setup. Now to see if I can find a '59 motor or switch out to replacement motor and arms.
PM sent
1959 3100 Apache Fleetside
hello Pathway,
I, too have a 59 pickup, and I've found that all the v-8
and heavy trucks have the electric wiper set-up. Stick with 58 or 59 to ensure correct parts. Often a heavy truck can be found in a salvage and they are good
parts sources for wiper motors.
Respectfully, 59shortfleet
