0 members (), 116 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1201979 01/29/2017 2:40 AM
ordered pre-bend brake lines from classic ind.... and have had to send brake lines back from being thewrong size I have a factory assembly book and these lines are sttill not right it has took at least 2-1/2 to 3 months , anybody got any suggestions........... Mike
mcannon #1202100 01/30/2017 12:44 AM
I usually just buy premade straight properly sized lines and bend as needed. Its not too hard to custom make them either with s rather inexpensive flaring tool set.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
mcannon #1202113 01/30/2017 1:48 AM
I used a 6 inch piece of fuel hose with a slit in it so you can slide it on the hose . Seems to work good and doesn't kink the line only difficulty is it sometimes slides off when bending .just have to go slow.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
mcannon #1202281 01/31/2017 2:52 AM
Thanks Guys, I am going with coppe- nickle lines and it will be right, THanks Mike
mcannon #1202355 01/31/2017 11:33 AM
I used a set of stainless lines when restoring my '52 GMC 1/2 ton from Inline Tube and they fit perfectly.
Mike
mcannon #1202371 01/31/2017 3:30 PM
Stainless steel lines from Jim Carter fit my 52 chevy 3100 off frame restoration perfectly just a very minor tweak or two.
