7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible),
75
10
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | So even after a friend warned me, I still screwed up the sending unit in the tank when I was rewiring. If I loosen the wire nut, I can get it to register the tank level correctly, but when I tighten it down, it moves and the gauge pegs to full. Has anyone done anything to fix this? Or am I destined to replace the whole unit? Thanks! | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Oh, right. '48 3600 with tank under bed. Thx! | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Sounds like when you tighten the nut it is grounding out. There is a write up if you search the posts about the sending units and how to check them out. My truck has the behind the cab tank and turnedout my problem was a float that filled with fuel. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | On the senders I've seen, that nut is on a stud that is insulated as it goes thru the flange and is connected to a stiff, insulated, conductive strap. Maybe you ae twisting that strap inside. Grounding that stud/wire should read empty, not full. Full should mean you are breaking connection somehow. Torque the nut so it is reading correctly while wire terminal is ON TOP of the nut. Then add another nut to sandwich the wire terminal without moving the lower nut. If there are already two nuts just be sure bottom nut does not turn when tightening top nut.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks Bartamos, I will have to try that. Just thought I would check to see if there were any other suggestions that might work. | | |
