| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | ordered pre-bend brake lines from classic ind.... and have had to send brake lines back from being thewrong size I have a factory assembly book and these lines are sttill not right it has took at least 2-1/2 to 3 months , anybody got any suggestions........... Mike | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | I usually just buy premade straight properly sized lines and bend as needed. Its not too hard to custom make them either with s rather inexpensive flaring tool set. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | I used a 6 inch piece of fuel hose with a slit in it so you can slide it on the hose . Seems to work good and doesn't kink the line only difficulty is it sometimes slides off when bending .just have to go slow. | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Thanks Guys, I am going with coppe- nickle lines and it will be right, THanks Mike | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I used a set of stainless lines when restoring my '52 GMC 1/2 ton from Inline Tube and they fit perfectly. Mike | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | Stainless steel lines from Jim Carter fit my 52 chevy 3100 off frame restoration perfectly just a very minor tweak or two. | | |
