2 members (KEVINSKI, 1 invisible), 105 guests, and 1 robot.
Topics128,034
Posts1,055,552
#1200598 01/20/2017 10:40 PM
This is for my '48 1Ton. The Huck brake setup front and rear is identical to the ones on my '48 Chevy 1Ton. That's good because the GMC manual doesn't even show what I've got!
The Chevy manual says to tighten the shoes until they just begin to rub the inside of the drum, then back off the adjustment a set number of cliks or flats of the adjusting bolt. Is this correct? On other vehicles I've always tightened the shoes until the drum won't turn, then backed off the adjustment.
Do the Huck brakes need more clearance than a conventional set up?
Thanks, Jim
I don't use the method of backing off a certain number of clicks. I back off until the drag in minimal.
1951 1 Ton Completed
I've followed the manual as stated for my GMC 1 ton and that worked great.
Also as mentioned you may need to adjust a little more if they drag. Good to check the drums for heat after a drive (not much stopping) and adjust any that are warm.
1952 Chevrolet 3800 pickup
---All pictures---
