3 members (TUTS 59, Southerntruck, Otto Skorzeny), 133 guests, and 1 robot.
Topics128,095
Posts1,056,067
Members48,433
So even after a friend warned me, I still screwed up the sending unit in the tank when I was rewiring. If I loosen the wire nut, I can get it to register the tank level correctly, but when I tighten it down, it moves and the gauge pegs to full. Has anyone done anything to fix this? Or am I destined to replace the whole unit? Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Oh, right. '48 3600 with tank under bed. Thx!
More images
Sounds like when you tighten the nut it is grounding out. There is a write up if you search the posts about the sending units and how to check them out. My truck has the behind the cab tank and turnedout my problem was a float that filled with fuel.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Sir Searchalot
Sir Searchalot
On the senders I've seen, that nut is on a stud that is insulated as it goes thru the flange and is connected to a stiff, insulated, conductive strap. Maybe you ae twisting that strap inside. Grounding that stud/wire should read empty, not full. Full should mean you are breaking connection somehow. Torque the nut so it is reading correctly while wire terminal is ON TOP of the nut. Then add another nut to sandwich the wire terminal without moving the lower nut. If there are already two nuts just be sure bottom nut does not turn when tightening top nut.
Thanks Bartamos, I will have to try that. Just thought I would check to see if there were any other suggestions that might work.
More images
