1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
hi guys i got a refurbished harrison heater but need to get hoses and connectors to the thermostat block and water pump housing. can anyone advise what the correct thread size is and hose diameter is?
unfortunately i dont have the truck with me to measure
cheers
mike
Drmike,
I know that the hoses are 5/8", inside diameter and 7/8", on the outside. Maybe somebody else will have the threaded fitting size. Hope this helps. Good luck with your project.
Rugo
Steve Rugg
53 3100
Make sure that the I.D. is true 5/8". I pulled the AirFlow from my '54 3104 to fix a leak three times before I discovered that the hoses were slightly oversize.
- Lonnie
- Lonnie
My '54 3104
