3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#119985 03/25/2006 3:36 AM
Ok I picked up 1 gallon of primer today and on the can, it says "1 1/4 part with 1 part" of VOC reducer. Well, the guy at the paint store gave me LACQUER THINNER.. but on the can it says mix with VOC reducer.. Is Lacquer Thinner the same thing as VOC reducer?
1952 Chevy 5 Window Restoration
#119986 03/25/2006 9:04 AM
dont know but just mix a 1/2 cup first to see if its compatable i waisted a gallon once
#119987 03/25/2006 1:27 PM
read the primer can,,most are lacquer primers unless you have urthane....doc
#119988 03/27/2006 4:55 AM
Junior Member
Junior Member
Blake
You don't mention, is it of the same brand? Most top brand paint companied will not endorse the use of thier product with that of another. Also all top brands Inmont, PPG, Sherwin Williams, etc, will have thier info and mixing directions on the web. Have you looked it up? Ask your paint guy for manufactureer data. You will get such things as mixing directions, dry time to re-coat, dry time to sanding, gun tip size and application directions, other recommondations and a lot more. If he is not willing to get this for you dump him and find another distributor to deal with.
Allan S Langley B.C Canada
#119989 03/27/2006 3:07 PM
VOC could mean Volatile Organic Compound or Volatile Organic Chemical.
Gasoline, kerosene, almost any thinner, and any organic solvent that evaporates at "normal' temperatures could be considered a VOC.
Lacquer Thinner is a VOC.
Different words mean different things to different companies and people. Here is a general definition: "Diluent: A liquid used in coatings to reduce the consistency and make a coating flow more easily. The water in latex coatings is a diluent. A diluent may also be called a "Reducer," "Thinner," "Reducing Agent" or "Reducing Solvent." "
As asked above, what is the brand (and line) of paint? You can't lose if you follow Capt. Al's advice. If your seller cannot provide clear information, the safest thing to do is to look on-line for what that manufacturer recommends for that paint.
