0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#119976 03/23/2006 6:23 AM
Junior Member
Junior Member
I'm working on my 66 C10
when I'm sanding body parts and I use a spray can of Rust converter.
Does it hurt to spray on bare metal ?
Anonymous
Unregistered
Anonymous
Unregistered
Hurt you or the metal?
The directions on the can should include instructions on its use which typically say to wash off exess with water which seems counterproductive as it can cause flash rusting. If you wipe it down quickly though it really is not a problem. I have used it on small areas and then wipe up the excess with a damp rag. Prior to any primer being used in that area I typically profile the metal with 80 grit on a DA and then degrease the area.
