| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | I'm working on my 66 C10 when I'm sanding body parts and I use a spray can of Rust converter. Does it hurt to spray on bare metal ? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Hurt you or the metal?
The directions on the can should include instructions on its use which typically say to wash off exess with water which seems counterproductive as it can cause flash rusting. If you wipe it down quickly though it really is not a problem. I have used it on small areas and then wipe up the excess with a damp rag. Prior to any primer being used in that area I typically profile the metal with 80 grit on a DA and then degrease the area. | | |
