2 members (PAUL Berardi, Guitplayer), 312 guests, and 4 robots.
Topics128,081
Posts1,056,078
Members48,434
Hi Stovebolters
I have located what looks to be a 95% done running and driving old Chevy truck (1949) it has a 1960's 327 Chevy motor hooked to a 4 speed transmission. It supposedly runs well. the whole project is based on an early 1970's Chevy truck with the older cab (1949) mounted on the chassis. From the pictures I have seen...seems to be pretty decent....body may need some work...but that is what they make patch panels for...
So from a driveline standpoint...(I have never had a V8 in anything I have owned)...so would it help in the drive-ablity end of things to swap out the big old school V8 and put maybe a 235 or a 250 in its place ???...or maybe get crazy and get 4.3 V6 and a 5 speed from an older S10 ???...
Just looking for possible options before I make a commitment to purchase this vehicle....
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
Going backwards (old motor) on a new frame may require lots of fabrication, but as they say...with enough time and money anything can be done.
If you really want an old school inline six, why not buy one already set up and stay away from the frame swap. The newer frame may be wider and the wheels may not fit nice...My ,02 cents.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
What's wrong with a 327? If the swap was done right you should have no issues. Very dependable street rod.
I'd like to see how that frame swap turned out. Do you have pics?
Hi Carl
It is currently 4 hours East of me, it is based on a early 1970's Chevy truck, stock front end, stock rear end too. From the pictures from the ad I have seen it looks like someone got sick of working on it...or ran out of money...or both..
Thanks for the insight guys...
MikeC
Howard Knapp
I cannot imagine putting a stove bolt 6 in anything but an older frame, and only because it's somewhat "period correct" and is in keeping with every other antiquated system in a 40's truck.
With a newer frame, I'd definitely keep the 327 drive train. As I continue to pour money into my 261 build, the mystique of driving a stovebolt is beginning to wear off!! Hopefully I'll feel different after I fire it up.
Post pics if you buy her- I'd love to see what they did and how it worked out. Good luck
~ Dave
Sir Searchalot
Sir Searchalot
Some great advice above. I agree with most.
My opinion:
1. Early Chevy Chassis= Good
2. 60's 327= real good
3. 70's drive train= good
4. 4 speed, depending which one= good-real good
5. 49 Truck body complete= good
6. How is was put together and how it looks/quality of swap= don't know til you see in person. Very important to me.
7. Buying it when you don't want motor/trans= waste of time. Unknown re-fabrication problems.
8. Title= good, No title= no good
9. Should be more worried/examine "needs some body work"= critical
10. Sale price?= 50% of the decision.
Unless some very creative body work has been done, there's not much way to make an early 50's cab and fenders fit over a 70's frame and running gear without looking really strange- - - -the track width is all wrong. It's the same reason putting the later IFS crossmember under an early straight front axle truck is difficult. The tires stick out from under the fenders too far, and if altered-offset wheels are used to correct the track width it screws up the steering geometry and makes the rig handle like a rhinoceros on a wet clay bank. Buyer beware!
Thanks for all the replies...I am still considering this project but thinking really hard on it too...I like the coils springs in the front and the back on this chassis set-up...I know my quad leaf truck that I had was a bear to drive and riding in it would shake your teeth loose too...and yes the track width does look wider in the pictures I have seen of it too...
scratching my chin again for sure...
MikeC
Howard Knapp
If you're very good at sheet metal work, you could graft about two inches of sheet metal into all the fenders front to back and move the overall width of the wheel openings out to cover the tires. That would make the vehicle 4 inches wider, but the tires would be covered and there would be less of a possibility of the tires hitting the fenders in a turn. Track width is why lots of frame swappers use the S-10 frame instead of a full size.
Carburetion specialist
C Online: Content
The first three items I would check would be:
(1) The title (clear)
(2) The title (your state's interpretation of the title)
(3) The title (your insurance companys interpretation of the title)
In Missouri, that thing would be titled as a 20xx Homebuilt; AFTER the highway patrol had inspected it.
Did you ever try to insure a 20xx Homebuilt?
Luck.
Jon.
The Carburetor Shop
