2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Apprentice
Apprentice
I have never worked with windshield glass before. I have a 54 Chev with a broken windshield and a donor 54 GMC with a good windshield. What is the best way to remove the good windshield so that I do not break it? By the By, I will have a nice five window 54 GMC (without windshield of course) for sale soon if anyone is looking for a project vehicle.
'57 3200 with V8 and not much else.
Use a sharp knife and cut through the rubber around the outside. When you peel the rubber away you should see adhesive which needs to be cut off as well and then just lift it out. Don't try to save the rubber or you'll break it for sure. Buy a pair of those suction cups with handles to prevent dropping.
You Tube
Call a glass shop and have them remove and install the windshied.When I did bodywork we never did our glass work we let the experts do it.The one time I tried to remove a windshield I broke it.
The crew that works on the \'42 --Sara, Hannah and Abby
I agree with dad6timz have a glass shop do it. OR you can do as IB said but cut the inside of the rubber along the pinchweld and have someone on the outside hold it while you push it out. Those windshields are thick and durable so breaking it shouldn't be an issue (no promise's)
bill
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
It'll cost you about $75 to have someone do all the work (not including the new rubber gasket). That will be $75 well spent when you consider the frustration and hassles you will run into. Call a few glass shops to get some prices before you jump into this one yourself. If you do decide to do it yourself, an extra pair of hands when it comes time to do the install will help alot.
AlZ Offline
Junior Member
Junior Member
cptchaos, I have sent you an email to your personal account. I will only be able to respond for one day as I am going on course for a couple weeks, if there is a delay in me responding, it's because of this.
Hey neighbour, do what IB says on the old glass first ,then see how you feel about trying it on the good one.taking it out is very easy ,it's puttin them in that can be a little tricky! lotsa lube, you can do it! grin
Bent Happy Haulin!
TWO 1963 GMC\'s -- A shortbox and a NAPCO!
