7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Some long bolts with heads cut off for alignment pins will save a lot of cussing and better chance of not messing up a gasket. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Yeah, I'm a step ahead of ya on that. The only issue is that they are 7/16" or 1/2" SAE. I don't have any laying around. I'm planning to swing by the hardware store on my way home and see what they got.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | Pick up concrete anchor bolts, they come in 12 to 14" length. They work great because the smooth shoulder is actually undersized making it easy to slide the pumpkin. Two of these pins and a floor jack it what I used to install my 2-speed pumpkin. Mike B  | | |
