2 members (55shaker, Steelonsteel), 117 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#1197228 12/28/2016 3:02 PM
So I'm finding out that nothings gonna be easy with this truck. Since its new to me, I'm doing some normal tune-up things. Not sure when Grandpa last did much to it. It's a 235 and the book says use 10mm plugs. It currently has Champion UY6 plugs. I'd like to use ACDelco and I get several when cross referencing but it looks like maybe the M8 is the one? I've seen people suggesting the R43 but that's a 14mm plug...maybe for the newer model engine. Any suggestions? When I look the truck up at different parts stores I don't get the option for the 2 ton loadmaster. 1 Ton seems as big as it goes. I would assume the 235 Chevrolet made for these trucks are all the same right? Whether it was a 2 Ton or a 1/2 ton. The wires need replaced as well.
Crusing in the Passing Lane
10 mm is not correct, try 14 mm.
Ed
Yes, the same 235 engine in the same year.
Same 10mm plugs on all 216/235 engines (all Chevrolet vehicles) through 1948. AC 104 (good luck finding that specific part number).
Have you checked Rockauto.com? They have the wrong size/ part for a 48 235, but the correct AC plug listed for the 216.
An R43 (14mm or AC 44-5 14mm) is simply the wrong size for any pre1949 216/235. At least, that is what the spec manuals show - see links below.
If your head uses a 14mm plug, you might have a later head on it?
http://www.rockauto.com/m/mobilecatalog.php?carcode=1486745&parttype=7212
http://chevy.oldcarmanualproject.com/chevyresto/4895.htm
http://chevy.oldcarmanualproject.com/chevyresto/4990.htm
Ooops, it looks like earlier 216 and 235 engines used different plugs?
1937 - 11mm
1938 - 14mm
1939 - 14mm
1940 - 14mm
1941 - 10mm
1942-46 10mm
1947 10mm
I'll look up and add/edit through 1947.
I've worked on lots of stovebolts - never seen one with 10mm plugs in it before. My '50 was as original as they come and it has the standard 14 x 1.25 thread plugs in it.
In fact - I've never worked on any engine with a 10mm spark plug in it. And that's saying something - been building engines of all sorts for 35 years.
1950 4100 - unrestored and driven weekly for almost no reason at all.
My 1948 original 216 on a panel truck had the original-spec 10mm spark plugs. I last worked on that engine 45 years ago. I still have the spark plug wrench for it.
As I posted above, by all 1950 and newer 216/235 engines had 14mm spark plugs.
H Online: Content
I'm currently working on unsticking a "1946" 235 (according to the ID code by the distributor) and it has 10MM plugs.
My son has a 46 2 ton with a 235 and the
original engine had 10mm and if I remember
right the new plugs I put in were a AC M8.
Jeffrey
Also keep in mind that some 1947 trucks are
1946 trucks titled as a 1947. As my son's case
He has a Art Deco truck and the model number: PW
is a 1946 year model number.
OK thanks guys. I figured the 10mm was right since that's what the book says and that's the plug that came out of it. My local NAPA has the AC M8 plug. I'll probably give it a shot. Thanks again!
