5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
Well, looking into front disc brake conversion kits. Finally sat down and started to read each parts shop catalog.
I ran across a statement in the Brothers Truck Parts catalog and it said that their disc brake conversion kit (booster under the cab, rotors, calipers, etc.) does not work on manual transmission trucks...
Anyone ever run into that? We have a manual trans truck and would like to install a front power disc brake conversion, and hopefully under the cab just to keep the engine bay clean.
1952 Chevy 3100 (235CI engine)
...T5 swap in progress...
This site covers trucks from the '20s to the '70s. They are not all the same. It's best to tell what model you are referring to.
Whoops, my fault.
This is in regards to the '52 we're working with.
Fox Offline
I would assume that the under floor brake booster would be the culprit. With your manual, the clutch pedal would likely "be in the way" of the brake boaster and you would have to heavily modify the clutch pedal to make it work with the booster. I haven't done this install but am curious as I may be doing it down the road in my 1/2 ton as well.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I installed the POL kit in my '54 with 3 speed manual and OD with no fitment problems.
I had a 1953 Chevy 1 ton truck with a stock 4 speed in it
looking at top view
from the bottom
this is a CPP kit..
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
Fox Offline
Thanks fellas. Those pictures sure cleared that up. It sits well back from the pedals. No problem...but that is down the road for me. 😉
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I have a cpp kit as well with minimal issues
Has anyone gone disc and used a manual master cyl setup? For my own reasons, I wish to avoid using a booster...
~ Dave
Y
yar Offline
Y Offline
Norcal Dave,
Where in Nor Cal are you? There is a great brake supply company in Santa Rosa. It's 2 brothers who inherited their dad's business.
No matter if I go in looking for restoration brake parts, street rod brake parts, daily driver brake parts or even a replacement axle and brakes for my travel trailer they either have or get what I need.
Regarding your unboosted disc question, my '32 Ford roadster street rod has that setup using GM "metric" calipers and Aspen/Volare rotors mounted on a Ford beam axle. Braking was lousy with the "organic" friction that is out there now. The local brake guys got me some asbestos pads and shoes and it was like adding a booster, no exaggeration. The pedal effort is kind of high with no booster but I don't mind that.
Ray
back yard wrench turner
W Online: Content
Yes I have disc with manual master cylinder. I used a 1 inch master cylinder. I also used residual valves for both the disc front and the shoe rear.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I'm in El Dorado County. I've got a friend in Santa Rosa though- what's the name of the business?
~ Dave
Wayne, how does the pedal pressure feel on your setup?
I didn't plan on running 4 wheel discs, but the rear end I am using is fitted with them so that's how it's going to be. I was figuring that I would need a 7/8" master to keep pedal pressures in a comfortable range...
~ Dave
W Online: Content
I have a good firm pedal but not so much I have to stand on it. I'm used to driving a non power brake car, my Mustang is also.
I used a 1 inch so I would have a little more volume of fluid being pushed to the brakes. It also shortens the stroke of the pedal.
Wayne
1989 Silverado
