9 members (tclederman, 57 Drifter, baldeagle, Cosmo, Paul_WNC, Bill Hanlon, gswbbc, HandyAndy, 1 invisible), 181 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
Hey, I have a 54 chevy 1 ton 3800. I haven't gotten it running yet but was wondering what were some ways I could improve the preformance of the truck so it can go over 45 mph. Currently it is all stock with a 235 engine in it. Any opinions on different gearing in the rear end or maybe overdrive trans? The 235 is in pretty rough shape so an engine swap could be a option.
Let me know what you think.
1954 Chevy 3800
"45 MPH" is a myth, sort of like the Easter Bunny, Santa Claus, and honest politicians. I owned a 1959 3800 for several years, with virtually the same 235 engine, SM 420 trans, 4.56 rear end, and 18" wheels that your 54 probably has. I had no problem cruising at 55-60 MPH, or more when necessary. I saw 65-70 on a downhill a few times, and the engine didn't come unglued. The truck will take it, if your tender ears can stand the noise. Yes, they make noise at speed- - - - -most people are just too timid to push the loud pedal.
Swapping 4.10 gears in the original axle is a simple and very worthwhile swap.
http://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/
Even though you can push the truck as it is and go faster like Jerry says the faster gears will make it more fun to drive at speed and burn a little less fuel.
Another option is swap the entire rear axle out for the right 14 bolt rear axle which have a range of gear ratios and brake options. Several discussions on the forum, check the 1 ton section.
I've done the first and planning to do the second, both have advantages and can work well.
1952 Chevrolet 3800 pickup
---All pictures---
Y
yar Offline
Y Offline
BJ60,
Here's what others have to say on your topic:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1194516/Re:_1953_Chevy_Truck_3100_top_.html
My Stovebolt is a '36 Chevy pickup with a much more anemic engine than yours. I swapped in a 3.55 rear gear set and even the little 207 engine pulls the 3.55 gears easily:
http://vcca.org/forum/ubbthreads.php/topics/334876/1936_Chevy_3.55_rear_gear_conv
Ray
The truck in question is a 1 ton which has different options for gear and axle swaps than the 1/2 ton trucks.
1 ton trucks also weigh more and have tall tires which are factors in what axle gear ratio you can get away with. 3800 gearing is not to be compared to a 3100.
---All pictures---
Thank for all the info. That should help me go a little faster. If I get a 4.1 gear ratio will it wear more on the transmission or clutch?
1954 Chevy 3800
Crusing in the Passing Lane
Surely no wear that one would notice, as long as one puts the trans in neutral at stoplights.
Ed
