1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | We had a storm the other night. My truck is in the driveway and exposed to the rain. I popped the hood last night to see a puddle of water sitting in the oil cap. The valve covers of these old 6 cylinders are vented, not sealed tight like a modern engine. I see 4 vent holes on the top of the cover. I assume the water came through the seam down the middle of hood. How much of a risk is it that water could leak in on top of the valve cover and down into the engine through the vent holes/slots?
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | it is quite likely. The amount of water would be the question. If you are uneasy about it, remove the valve cover for a look,soak up any water with paper towels,drain the oil without starting the engine. Fresh oil,and you are done. Any remaining moisture will evaporate at operating temperature | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Did you leave the hood open?
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Check the hose from the front cowl vent. Could be turned directly toward the valve cover instead of down the firewall Kevin
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I did not leave the hood up. I think it had to come through the seam in the hood.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | mine will drip through the seam a bit. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I am reviving this discussion to see if anyone else has come up with a solution to this. After watching it for a while now I am 99% sure the water is coming through the seem in the hood and leaking on top of the valve cover. The design of the cover allows the water to puddle on either side and fill up to the point it looks like it could or is running into the vent slots in top of the cover. Has anyone separated the seam of the hood before and reassembled it? I was considering trying to pull the two halves apart and reassembling after adding a bead of silicone to seal the seem. Is this a mistake? Will I ruin the hood if I separate the two halves? Can the two halves be separated? Any other suggestions? I don't want to have to pull the cover and dry out the top of the engine every time it rains. I can't be the first bolter to have this issue. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | If you use a sealer on the seam, don't use silicone. Use a urethane type that is paintable! They make some clear spray-on sealer called Flex Seal "as seen on TV". I bought some at Lowes but ended up not using it and took it back. You might spray that on the under-side of the seam, under the hood. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Make a deflector about 6" wide and attach it to the underside of the hood under the seam. If you put a little radius in it or even a slight V bend the leak, if any, will stay away from the valve cover. Then you can deal with water dripping onto the distributor cap. Jerry
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Good idea. That is a lot less risky and labor intensive than pulling the hood apart would be. I will make a little umbrella for the distributor cap. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I would be concerned with oil getting in the engine but not much about a little water getting on the dist cap. I had a 1950 DeSoto with a louvered hood. It was our daily driver. (I live in Seattle so, lots of rain!) It got plenty of water on the dist cap as well as on everything else under the hood, we never had any issues with it from water. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Yea, even without a leaking hood any car has the potential of getting a lot of water splashed on it while driving in the rain. The small umbrella was my poor attempt at being funny. Why make one? I am going to save one from my next fancy cocktail. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Just make sure you don't drive a Jag XKE. Those things would drown out the ignition if somebody spit on the sidewalk two blocks away! Of course, they DID have a Lucas electrical system, and the Brits drink warm beer because they have Lucas refrigerators! Jerry
| | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | My solution was to purchased one of the vintage C.A.W. cast aluminum valve covers and a vented oil fill cap. The valve cover is bath tub. no water or crud can get in it. The cost was worth the $. There always is one on Ebay. The Wayne, Offenhauser, Fenton.etc valve covers are cheaper but at the moment not in production. I made some inquires and Offenhauser broke their mold and MAYBE be back up in 2017. The caw looks more original not too flashy, with a little history. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | It's also possible to flatten the vent slots and TIG weld them, then go with a vented oil fill cap. Jerry
