1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 47 | Well, looking into front disc brake conversion kits. Finally sat down and started to read each parts shop catalog.
I ran across a statement in the Brothers Truck Parts catalog and it said that their disc brake conversion kit (booster under the cab, rotors, calipers, etc.) does not work on manual transmission trucks...
Anyone ever run into that? We have a manual trans truck and would like to install a front power disc brake conversion, and hopefully under the cab just to keep the engine bay clean.
1952 Chevy 3100 (235CI engine) ...T5 swap in progress...
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This site covers trucks from the '20s to the '70s. They are not all the same. It's best to tell what model you are referring to. | | | | | Joined: Dec 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 47 | Whoops, my fault.
This is in regards to the '52 we're working with.
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I would assume that the under floor brake booster would be the culprit. With your manual, the clutch pedal would likely "be in the way" of the brake boaster and you would have to heavily modify the clutch pedal to make it work with the booster. I haven't done this install but am curious as I may be doing it down the road in my 1/2 ton as well. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I installed the POL kit in my '54 with 3 speed manual and OD with no fitment problems. | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | I had a 1953 Chevy 1 ton truck with a stock 4 speed in it looking at top view from the bottom this is a CPP kit.. MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks fellas. Those pictures sure cleared that up. It sits well back from the pedals. No problem...but that is down the road for me. 😉 | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I have a cpp kit as well with minimal issues | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Has anyone gone disc and used a manual master cyl setup? For my own reasons, I wish to avoid using a booster...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Norcal Dave,
Where in Nor Cal are you? There is a great brake supply company in Santa Rosa. It's 2 brothers who inherited their dad's business.
No matter if I go in looking for restoration brake parts, street rod brake parts, daily driver brake parts or even a replacement axle and brakes for my travel trailer they either have or get what I need.
Regarding your unboosted disc question, my '32 Ford roadster street rod has that setup using GM "metric" calipers and Aspen/Volare rotors mounted on a Ford beam axle. Braking was lousy with the "organic" friction that is out there now. The local brake guys got me some asbestos pads and shoes and it was like adding a booster, no exaggeration. The pedal effort is kind of high with no booster but I don't mind that.
Ray
| | | | | Joined: Sep 2010 Posts: 1,703 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,703 | Has anyone gone disc and used a manual master cyl setup? For my own reasons, I wish to avoid using a booster... Yes I have disc with manual master cylinder. I used a 1 inch master cylinder. I also used residual valves for both the disc front and the shoe rear. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I'm in El Dorado County. I've got a friend in Santa Rosa though- what's the name of the business?
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Wayne, how does the pedal pressure feel on your setup?
I didn't plan on running 4 wheel discs, but the rear end I am using is fitted with them so that's how it's going to be. I was figuring that I would need a 7/8" master to keep pedal pressures in a comfortable range...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Sep 2010 Posts: 1,703 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,703 | Wayne, how does the pedal pressure feel on your setup?
I didn't plan on running 4 wheel discs, but the rear end I am using is fitted with them so that's how it's going to be. I was figuring that I would need a 7/8" master to keep pedal pressures in a comfortable range... I have a good firm pedal but not so much I have to stand on it. I'm used to driving a non power brake car, my Mustang is also. I used a 1 inch so I would have a little more volume of fluid being pushed to the brakes. It also shortens the stroke of the pedal. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
