7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass), 105 guests, and 2 robots.
Topics128,059
Posts1,055,825
#11964 02/14/2002 1:14 PM
Got a leaky radiator and have resolved to putting a new one in. I'm running a 350 v8 with a 350 tranny. It has an external tran cooler. Can an external and internal cooler be used together? Or would you plug the one on the new radiator and use the external one or do away with the external and use the internal? Not even considering repair of old radiator. Thanks
#11965 02/14/2002 3:02 PM
I would plug the internal and use the external.
Auto trannys make plenty of heat and the coler they run, the longer they will last.The use of the external cooler only will keep the heat from the tranny out of the radiator too.
