1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#1195679 12/17/2016 1:08 AM
I have a series 2 55 chevy and I am looking to swap in a late/later model chassis and was wondering if anyone has done this? if so which chassis was used ? c10/Tahoe/Yukon????
if you have done this any info you could provide would be greatly appreciated
thank you
Guycamm55 #1195777 12/17/2016 6:58 PM
You could take a look at the link below. There are other options, including disc brakes on the straight axle or a front clip on the original chassis. Depends on what your goals are for using your truck.
http://www.e-zchassisswaps.com/kit.php?category=5
Guycamm55 #1195788 12/17/2016 7:56 PM
You can make anything work if you are willing/able to fabricate.
A 55-59 body on a Tahoe/Yukon chassis would be a spectacular combination. I have seen a Tahoe do unbelievable feats pulling out stuck vehicles in loose sand.
Guycamm55 #1195914 12/18/2016 10:58 PM
thank you for your replys..
1st off I would want my truck to handle like a fairly late model truck...what chassis would be the right fit ?
2. I thought I needed a chassis that has the same wheel base as what I have
3 I would prefer to buy a chassis that has disc brakes all around ,w the up to date front end . so Im shopping around for such a chassis
Thank you
Guycamm55 #1195915 12/18/2016 11:24 PM
I can suggest a tape measure and a junkyard. One thing to look out for other than wheel base, is big humps in the "new" frame. Your stock frame is pretty flat. If the "new" isn't, you will need to do some extra fabricating to make it work.
Guycamm55 #1197863 01/02/2017 12:00 AM
Go to this forum and ask there. They are a good resource for what you are looking for.
http://67-72chevytrucks.com/vboard/forumdisplay.php?s=&daysprune=-1&f=13
