4 members (Gray_Ghost, Jon G, Otto Skorzeny, 1 invisible), 96 guests, and 8 robots.
Topics128,181
Posts1,057,189
Members48,465
Found my old Hoppy Lev-L Lite Headlight aimers in the attic behind boxes we had Christmas ornaments in. Got it down and everything still works except the suction cups are dry and won't stick to the headlights. Tried water and spit but they still won't stay put. This is the old headlight aimers with the pull back, hole in the center of the suction cup vacuum holding device. No one seems to have new suction cups available for this unit. Too old I guess...from the 70's. Is there anyway I can rejuvenate these suction cups, or do I just have a dinosaur at extinction? Hate to dispose of this unit as it is in excellent condition. Yes, it has good vacuum if you hold your finger over the center hole in the suction cup. Any suggestions on how to make these suction cup function again would be greatly appreciated!!
Tim
1970 VW Beetle
Red rubber grease?
Maybe just some brake caliper high temp grease.
No alcohol... for the rubber. For you, apply as needed.
Give me ambiguity
or give me something else
Caso,
Thank you for the input! Won't the red rubber grease or caliper grease cause the suction cups to slide on the head lights?
Tim
1970 VW Beetle
There are all sorts of suction cups available on Ebay- - - -(dent pullers, etc.)try finding some about the right diameter and gluing them to the inside of the existing cups with 3M trim cement (gorilla snot). Can't lose much- - - -they're useless "as is".
Big Bolt Forum Moderator
maybe some silicone spray to soften the rubber? If they are just too dry and won't stick, a little soapy water may do the trick!
Mike
Moderated by  MNSmith
