| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 92 | I should have put this question here instead of the big bolts section. I need to put a floor mat in my '63 GMC 4000 truck. The floor in my truck has no hump. Will a floor mat for a '63 Chevy/GMC with an automatic transmission fit my truck? Are the floor panels the same? Thanks JP | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I think all 1963 1/2 ton & 3/4 ton trucks have a hump. None are flat. To my knowledge, all the 1960-66 reproduction floor mats are molded for the hump. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are no rubber matts available for what they call a 4 speed hump. The supplier no longer available. They do sell a 3 speed matt. Called "3 speed, small hump" for 60-63.
I just received the 4 speed carpet. All vendors are out of stock for the 4 speed rubber matt and have been for years. The 55-59 is the same situation. For my 1960 GMC, I almost bought the 3 speed and was going to split it in middle and add black carpet or something. Changed my mind. Where do you see a 1963 rubber matt for "automatic" being offered? The 4000 has a different cab than 3000 and lower models. Don't know about the floor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2014 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 92 | I guess I should have said there was a mat for a "column shift" pickup and not automatic. That's what I was afraid of that I wouldn't be able to use a pickup mat. Thanks for the info. JP | | |
