1 members (Bill Hanlon),
167
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | I currently have a hot rod 1946 Chevy 2 ton. I am considerng upgrading the front and rear axle, maybe the entire chassis, to some more modern equipment.
My questions are: Would the original rebuilt front axle be of interest to anyone? New wheel cylinders, wheel bearings (expensive!!!) and rebuilt kingpins.
Rear axle, 2 speed, new wheel cylinders, running just fine now.
Just pondering some possible future upgrades.
1946 Chevy 2-Ton Rat Rod Wrecker
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC 3000 and 3500 (p) have 5/10 on 7.25" bolt pattern, if that matters, they also have power steering and hydroboost brakes, find a whole truck. Wide front fenders will be required, however, I have pair if you wish px. 5/10 bolt pattern is great for stock wheels, tubeless 22.5 wheels are hard to find, perhaps another bolt pattern would be desireable?
Ed
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | Currently running the original wheels with 9.00-20 tires. Not sure what the future wheel and tire combo might me. I suspect 8 on 6.5 or the larger 70's/80's RV big truck pattern.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You could/should list your parts for sale in the Swap Meet section, if/when they are for sale. (not here) Start with what you have in them and see if they sell, adjust the price as needed until they do sell.
I wouldn't expect a lot of calls but someone looking to rebuild their axles could be money ahead if yours are done right and are easy to fetch. Add long distance shipping and might not find any buyers.
Good luck, | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Try finding a newer good driver & set your cab on that chassis. Something 10/15 years old or newer. That would be a nice up grade. Power steering, independent suspension, power disc brakes. The motor & drive-train/ wheel-tire size will all match as a unit. And you will have all the accessory stuff you will need to get it back on the road. Air-conditioning & most of the wiring should transfer over to. Plus everything will be from one make model. You might have a easier time selling your old drive-train as a complete running chassis? The old frame rails may be worn & tired anyways? I wish I had gone that route when I started my 39 COE project. I'd be driving it already.
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
| | | | | Joined: Jul 2009 Posts: 29 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 29 | I have a 70's 1 ton cab and chassis I could use. I want the keep the 454/th400 I currently have.
The downside is that the current(original with some modifications) rolling chassis is in perfect running and driving condition. As stated above, rebuilt front axle, running 2 speed rear, all new wiring and plumbing. I am kicking myself at the thought of all the work this move may cost me.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Consider driving the truck like it is. Find another cab and front clip to make your second truck. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Second, keep existing one just as you have fixed it up.
Since you know how to do it, second one will go much faster.
Ed
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I have a 2-ton that I use for my business. It is all stock except for the disc brakes I put on the front and the 12V alternator. It gets used weekly and most of my employee's have learned to drive it.
I agree with Grigg and EdPruss above, keep it as is!
| | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | I'd leave it be. I have a '50 4100 that I contemplated doing the same thing to - but I decided its 10 times neater in stock form. It draws more attention, too. People are astounded at the originality of it and the fact that the original engine still runs, etc.
1950 4100 - unrestored and driven weekly for almost no reason at all.
