8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | The hood on my 1949 3100 fit really well at the front, bottom sides and rear by the cowling. 1/4" gap all around. Rear of hood sits tight on the cowling seal when closed except at the rear sides of the hood. The rear sides stand off the side cowling about 3/16"-1/4". The center of the rear of the hood sits below the top edge of the cowling by 3/16". Is there a way to adjust the rear sides of the hood and bring them in as well as bringing the rear center of the hood up even with the center of the cowling??
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | There is a bracket under the hood at the rear, in the center. There are bolts with shims under them which can be removed or added to fix your problem. Unfortunately the Shop Manual is sketchy on what adding or removing the shims will do in terms of raising or lowering the center of the hood, or moving the sides in or out. I'll bet it will all be clear to you once you take a look at the bracket/shims. Carl
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Karl,
Thank you for the words of encouragement!
I saw the bracket at the back of the center hood that has 4 stovebolt screws and star washers. Not sure how that bracket would raise or lower the center of the hood and bring in the back sides of the hood? Shims? Body shims or washers? Guess I can figure it out, but any advise or suggestions would be helpful! If I remove this bracket will the back of the hood separate? Can I remove this bracket without causing any further difficulties?
Tim
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | It really changes things, believe me...
If I recall in the tech tips section here there are directions. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | If I remove this bracket will the back of the hood separate? Can I remove this bracket without causing any further difficulties?
Tim Underneath the bracket, the two hood half brackets are spot welded together. Removing the small bracket won't cause the hood halves to separate. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | MNSmith,
Thank you for the information on the rear center support bracket on the hood. My hood is sitting low on the cowl at the rear center. The shop manual leave much to be desired explaining what this bracket does. I see that the FSM explains how to adjust if the hood sets high on the cowl by placing washers on the end of the bracket, but not how to adjust if the hood sets low at the center cowling? Anyone had this situation? What was done to correct it?
Tim
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I would think that if you shimmed it in the direct center of the bracket, it would raise the center. | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I think remove the outer shims raises the center??? | | |
