1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
#119468 02/07/2006 7:15 PM
So I cut the passenger side outer cab corner on my 57 3100 and discovered there is an inner cab corner as well. Since most of the metal was rotted anyway I just pulled the two apart from each other, ordered new inner cab corners and am now looking at a much more involved process than I expected. This may seem like a silly question but this is my first attempt at restoration, how does one remove the inner cab corner? Are there spot welds that have to be ground off? Do I just cut with a cut-off wheel the section that needs to be replaced? Do I remove the entire inner cab corner and if so, how? I get to do the drivers side after I finish the passenger side and then I have the lower front fender patches to do on both sides. I used to be able to ask my dad about matters like this but he has been gone some 15 years now so I must ask my fellow 'bolters. Thank you for any guidance.
#119469 02/08/2006 3:56 AM
Just cut out the rotted section and cut a matching piece from the new panel. Weld it in. No need to remove the whole inner cab corner if it isn't necessary.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#119470 02/08/2006 3:35 PM
On my 57, it was spot welded in. Look carefully & you will see how it fits. I replaced the whole thing, in part because I also replaced the step, so it just turned out to be a cleaner job that way.
#119471 02/08/2006 4:34 PM
flyinv55,
If you can sandblast the area first, you can get a much better view of the spotwelds and the extent of damage from rust/pinholes etc.
The clean metal allows you to draw nice layout lines with your Sharpie to follow when you remove a section for replacement.
Stuart
#119472 02/09/2006 8:33 PM
Nice tip Stuart
Very good idea
Regards,Sharpie Steve
#119473 02/09/2006 10:17 PM
You could cut the patch panel first, hold it up to the truck, mark around it, and then cut INSIDE the lines you marked.
Or, you could cut out the rotted piece and place it against the patch panel, draw your lines...
#119474 02/11/2006 9:38 PM
It's generally good practice to cut all the rust out and fit the patch panel to the hole you have created, rather than the other way around.
Paint & Body Shop moderator
