| | | Forums66 Topics128,088 Posts1,056,372 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | These are a pain in the rear to install as they are three separate pieces. Does anyone know of a company that makes one piece gaskets? Sure would make it easier to install when using two piece cast iron headers.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Size and year engine?
If 216/235/261, are you using the alignment rings? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Tim, It's a 59 261 .060 oversize with a Howards m4f cam, been running it for 10 yrs. Just cleaned up engine, and when putting it back together got frustrated trying to hold the intake and two fenton headers and the exhuast gaskets all together with one hand. While trying to put bolts and clamps on with the other. yes the alignment rings are on the engine.
Just seems like it would be simpler to have a one piece gasket that would be held up with the two end studs/posts.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Pre'68 Dave,
Thanks for that info. That looks like a solution, though a little pricey. It may well be worth it for the aggravation of trying to hold everything and three gaskets.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | ^^^^^^^^^^^^ until you add the shipping | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yep, you're right. About 40 cents higher with shipping. Dang pennies anyway.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | regardless of the price, this material can't be beat. If installed with any sort of care at all, you will never have a leak. We fought the old standard gasket material for years where I worked in Alaska, then somewhere this showed up, never a problem, ever. Not to mention it is really easy to cut if you need to buy some sheet stock and make your own gaskets for anything else. | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | I agree on the material. I've had some installed on mine since march, it still looks exactly like it did the day I installed it. It was easier to get in place, it was leak free on the first try, doesn't seem to be deteriorating, and other than collecting a little dust I'm betting it will be there until the next time I need to remove the manifolds for other reasons. Only down side was I had to cut my own for the between manifold gasket because I couldn't find a precut one for my year model, but it was easier to cut than standard material. I have a review thread on it on here if you want to read more, I think it will come up in a search. Time will tell, but previously I had to replace my standard gaskets about every two years, always one exhaust port would give out, usually not the same one as the last as the material just deteriorated to the point of blowing out. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I didn't see that it was available in bulk for cutting ones own, did I miss that?
Ed
| | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | They have several sizes of blank sheets available. I'm not sure what vendors stock them, but I purchased mine from the manufacturers web site. Might not have been cheaper but was close to at least one vendors price once shipping was included. They offer a decent selection of precut ones on there that you might not see at some vendor sites as well. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Thanks, I'll try there.
Ed
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I have a Buick straight 8 engine and it's manifolds are even longer than the Chevy ones and very prone to warping. After surfacing the manifold to head surface several times the alignment rings were too wide for the manifold to seat against the head so I shaved a bit off of two rings for alignment, threw the gaskets in the trash and used high heat RTV RED silicone. Been at least twenty years with no exhaust leak. The RTV silicone seals with adhesion, not compression, so all surfaces have to be operating room clean and let to cure at least a day at normal temperature. I left mine cure a week. Picture is when sealant was about 15 years old and is starting to peel around the edges but still not leaking. http://s32.photobucket.com/user/coilover/media/Straight%208%20a-c%20mount%20001.jpg.html
Evan
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I received one of those gaskets today (from Amazon). Very impressive - it looks to be at least 4-times thicker than an original gasket.
Remflex Exhaust Gaskets 1937-1963 CHEVY 216.5/235/261 2027 | | |
