| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Anyone know what diff ratio a 1952 Car diff is?
I found some one selling the whole 1952 rear end including torque tube in my area and I was wondering if I could swap it into my 37 Chev 1/2 ton Pickup to get better top speed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Not sure it would mate up to your transmission or if it is the same wheel base but a 52 car would have a 5 lug bolt pattern. Fred
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Den, I've been through that exercise: http://vcca.org/forum/ubbthreads.php/topics/334876/1936_Chevy_3.55_rear_gear_convYour '36 PU has spiral bevel gears and the '50-'54 Car rear ends are hypoid so swapping in the gears is not an option. Swapping in the whole rear end probably won't work either because of differences in track, spring mounting method, driveshaft length, driveshaft splines not matching your U-joint and 5 vs. 6 lugs. You might consider a '37 car rear end and swapping in the gears you want. That will eliminate some of the problems.
Ray
| | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | | | |
