| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | getting ready to paint inside round bed rails and wondered what y'all used to apply etch primer and top coat to the inside? I think no matter what I do it is going to be messy...
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Recently used a "modified" small diameter low nap paint roller to get some epoxy primer inside a rocker panel.. Main intent was to seal up the lower pinch weld seam to prevent water from collecting there. We mixed up epoxy, dumped inside the rear quarter area to let it run inside the rocker, and used the long paint roller to push it all the way to the front. http://www.garagejournal.com/forum/showpost.php?p=6133310&postcount=2144I would think you could use a threaded rod to hold a paint roller and coat the inside of your tube with epoxy primer in a similar fashion. But as you say, it will be messy.. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I used an old sock and push it thru with a broom stick tied to a string Dan | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Turn the bed upside down so the gap in the rolled edge faces up, then use a small diameter paint roller attached to the end of a broom stick to spread the primer and/or paint. Jerry
