2 members (Peggy M, crenwelge),
173
Mod | | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Any suggestions & sources for cabinet blast media?
I've been using sand and glass beads and don't like either for rust removal.
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I like aluminum oxide, that is what a blasting company recommended when I decided I did not like sand. I do not think glass is tough enough for rust removal, nor plastic. There is also silicon carbide. I have never used it, but bet it is really tough, I wonder if it is expensive. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John,
I have one cabinet with glass beads and another with aluminum oxide. In the glass bead unit I have used several different " grits" of beads.
Both cabinets work great on everything I have put in them...nasty rust to light. I wonder if it isn't the media, but the cabinet or air supply or gun.
I feel that sand is a "once through" media and isn't suitable for a blast cabinet, unless you are going to change it often. The coarse glass beads are quite aggressive and will take rust off most anything. If you aren't getting the results you expect, I would look at the system, not the media.
Stuart | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I have used both Glass bead and aluminium oxide in my cabinent and I find I use the aluminium oxide most often for paint and rust removal. I buy my blast media from an industrial supply house in Rochester, NY.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | You can buy blasting medias from Eastwood. They recommend aluminum oxide as the best media to remove carbon, rust and paint. http://www.eastwoodco.com/jump.jsp?itemID=1313&itemType=CATEGORY&path=1%2C2%2C1310&KickerID=243&KICKER | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Aluminum Oxide or crushed garnet are good. Be careful with that sand, even in a cabinet - whenever you open it, some free silica is going to get loose.
Try a farm store - even if they don't carry media, they can probably get it for you...or check out Harbor Freight/Cummins type stores if you have one nearby. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Northern Tool carries black oxide and Tractor Supply carries Garnet and glass. Do not know if either are in your area though. | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | I wish we had a Tractor Supply here. The closest one is about 2.5 hours away in Leesburg, VA.
I ended up taking your collective advice and I ordered 50 lbs of Aluminum Oxide from TP. I had them throw in a small parts basket while we were at it.
Yeah, I was using silica sand. I was using a respirator, too. But the dust was awful and I couldn't see. I'm going to clean the whole thing out, replace the window shield and start over. Maybe it will be fun to blast again...
Thanks for the advice! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Make sure you have an inline drier on the air feed. Gets nasty without it. | | |
