7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy),
67
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Anyone with a quick link or two for the factory paint colors for a 1950 1/2 ton truck? Thanks! | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Assuming Chevy, here are the charts for '49: Page 1. Page 2. The colors were the same for '50, except for the Fathom and Channel greens, which were used on the 'burbs in '49, but were discontinued in '50.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Many thanks, yes, it's a '50 Chevy | | | | | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | Do you happen to have the same charts for a 51 Chevy 3100? I've seen the listing but not the sample of colors.
1951 Chevy 3100 w/235
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The '51 colors were the same as in the '49 charts (except for the two greens mentioned above). Here are links to the '51/'52 charts anyway: Page A. Page B. Note that Jet Black and White are not shown in the '51/'52 charts, though they were available. The color chips as seen on the computer screen are not necessarily accurate representations. It helps some to turn your screen brightness and contrast way up.
| | | | | Joined: Feb 2006 Posts: 1 Junior Member | | Junior Member Joined: Feb 2006 Posts: 1 | was there any factory 2 tone colors available?
It'll all come out in the wash.
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | | | |
