8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#1193008 11/29/2016 7:15 PM
Hey guys, I have been lurking in the shadows for some time and finally signed up as I am getting closer to the moment of truth. I brought home my 1950 GMC COE from Kansas to mate the cab and pedestal to a 1973 p30 frame that has a rebuilt 454 th400. I am hoping to leave the cab and cab pedestal stock height. 1973 is the first year that GM had the hydroboost and it is frame mounted. I hope to relocate it to the cab pedestal in the old location.
My search for information on mounting the pedestal to the p30 has come up dry. it looks like the front cab mount perches need to go where the p30 IFS is. what have you guys done? also will the cab floor clear a stack 454 on a p30 or do I have to move it back and down? any help and pictures would be awesome!
3B Online: Content
3 Online: Content
Hy falcon6574, welcome, I believe you would get more/better response to your question if you posted it in the High Perf forum, good luck with your project.
Hi, I have my 1939 Chev cab on a 1980 P30 frame, "step van-bread truck frame" My hydro-boost was on the firewall, & it fits perfectly on my 1939 firewall. You should have plenty room on your 1950 cab. If you can find one, that should fix your problem.
You will want everything down to the swinging brake peddle.
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
Thanks! how do I get this moved?
Moved? Not sure what you mean. If you get everything from the booster to the peddle, it's all there & it all mounts to your firewall. Everything else is Hydraulic brake tubing. My 1980 frame has front dis brakes, 73 may have drum brakes? If you can find a GM step-van of the 80s, check out there brake system.
I just checked my photo album, I don't have a photo of the booster mounted. I hate this new computer, I have more photos some-were but I can't find them.
It mounts to the firewall with a rod that goes through the firewall to the swinging peddle. The peddle swings off brackets under the dash. You will see that it all comes together. If the swinging paddle is not the length for you, you can lengthen or shorten that.
Darrell, W.L.
He meant the thread, I believe
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
http://pin.it/5H6ss7T
here is a link to my photos. you can see the hydroboost on the early frame
