7 members (walterhvogel, Jman, Tom McGrath, UtahYork, Materman, Rich'sToys, Wally / Montana), 107 guests, and 3 robots.
Topics128,035
Posts1,055,557
#1192614 11/27/2016 2:16 AM
can I safely guess this is HO52 ?
axle
I had raised it and counted rotations a couple
months back, but didn't write it down.
Might be a 4.10
I'm reading thru the TechTip on axle swap.
I will keep this, though, since whole thing original.
Until I retire, I'd like to see it hit 60mph.
1960 C20 Platform
dbwr #1192618 11/27/2016 2:32 AM
Yes, that is an HO52. What year truck is it in? Also, can you get the code from it? The code should be on the third member.
Bill Burmeister
dbwr #1192628 11/27/2016 3:08 AM
If it came from a C20 with a V8 and an automatic, there is a good chance that it is a 4.10. The ring gear will be stamped 10-41 if it is.
Matt
dbwr #1192686 11/27/2016 5:28 PM
(I put 1960 C20 on sig line.)
They tell me it's all original.
I've tried to clean crud of all around
axle/pumpkin, but I can't find any markings.
Will get a super bright light and look again for markings.
Thinking about pulling whole drivetrain :
engine, tran, axle - while I rebuild 235 and check
rest out. Don't need it as a daily driver, but
I'm 6'3" and only current vehicle I can fit it.
(oh, no, not selling any parts - will put back
together later)
1960 C20 Platform
dbwr #1192694 11/27/2016 6:36 PM
Unless it has been changed it would be 4:57. As previously mentioned the 4:10 came with an automatic on 67-72 trucks.
Fred
rfs56trk #1192699 11/27/2016 8:01 PM
4.57 sounds right.
Tops out at 45 mph, which is speed limit of
short drive to work. I had a '65 Ch with an
4.10 Eaton partial-locker which exploded one day.
My brother found a 2.83 ( ? or somewhere around there )
and it made a huge difference.
Actually used granny low off the light.
4.57 only good for parades and farm work.
(bought it in Wy, hence the corn field in pic)
1960 C20 Platform
