| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Posted this in "The Doors" but no response. Thought I'd give it a shot here.
Is it nessessary to remove and reuse the old flat metal clips from the old window channels and reuse them on the new ones. If so, how do you "crimp" them in place without destroying the new channel. I removed all the clips and they are all in good shape, just wondering if I need to bother, or if the inside window frame and the channel screws are enough to hold the new channel in place.
Or is it acceptable practice to put small panhead type sheet metal screws through the new channel into the window frame.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you talking about the staples? It is common practice to use screws on the new stuff because the staples require a special machine to insert.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | no, the metal pieces that hold the channel run tight against the out side of the window frame. Maybe some had staples, I don't know, but mine had pieces of metal about 1/2" wide by about 1 1/2" long and were attatched to the old channel. They have four little tabs shaped like this.... < > < > ....and the tabs are kind of "pierced" through the metal. I got some really small screws, I think I'll try that. Thanks.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Are you talking about the "whiskers" that go on the window frame? The window frame that comes out of the door and is usually chromed?
Those were stapled in, I screwed mine with a tiny sheet metal screw. The channel that goes around the door, again, screwed it in. I think those originally did have a U shaped metal clip that surrounded the channel so it would hook into the door when installed.
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I used small pop rivets and it worked great!
Steve | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Martinsr, I originally was talking about the channel that goes around the door. I installed one the other night with tiny screws and I'm satisfied with the results. I also did the same with the whiskers on the inner window frame and I think it turned out very good. I buried the screws deep enough into the whiskers that they won't scratch the glass, and they are hard to see.
Steve, guess what came to mind after I had finished the other night, that's right, pop rivets. I wish I'd have thought of it sooner, I bet they worked very well.
