| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | I want to make kick panels for my 49 but I don't have the metal track/rubber gasket yet for the inner door opening. does anyone know how much room the track /rubber take up fom the edge of the door post hinge side. should I wait. thing is don't have money for tracks/rubber right now but I have an upholstery friend that ows me | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If you just need the bottom section of the c-channels in front of the door openings, you really don't need them at all. You can simply screw that portion of the rubber in place with small black self-tapping screws through the rubber. The screw heads nearly disappear. You can put your kick panels on now and just screw the rubber on through the edge of the panels and into the inner cowl panel later. Carl
