| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | My '71 Vandura has a three-on-the-tree manual with a 250 straight six.
What manual transmissions are out there that would give me more than three forward gears? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I mostly know about the T5 transmissions found in Chevy S10 and GMC Sonoma trucks. Camaros and Firebirds used them too. They have overdrive and can be made to bolt right up to your bell. However, you would be changing from column shift to floor shift.
A Muncie T10 4 speed would add another gear but final drive is still 1:1 so you would not gain anything.
Some GM vehicles used a 3 speed with an overdrive that was solenoid operated. I know they are very nice if you can find one. | | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | Yes, floor shift would be necessary. Thank you for the info. I see you have a link to some pages about the T5. I'll have a look. | | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | Before being led to your T5 compendium, I was thinking about the Muncie trans with a solenoid OD. Is the BW trans better made than the Muncie? | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Muncie transmissions were available with a BW overdrive from 55 through 65. Also known as an SM319. This transmission is non syncro first gear and can be identified by the 4 bolt side cover. In my opinion it would not be a very good match for your van. There is a better option which is a Saganaw transmission with the BW overdrive which was available from 66 through early 70. It is full syncro and would use your same column shift arrangement along with the correct driveshaft yoke. The Saganaw unit can be difficult to find and pricy. It can be identified by the 7 bolt side cover. For the record Warner made the earlier transmissions for Ford, Studebaker, and others. Borg Warner made the OD units. Fred
| | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | Is that Saginaw a three-speed?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The OD unit makes it effectively a 4 speed, even though there are 3 shift positions. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Actually, above about 30 MPH in 2nd gear, the OD can be engaged as soon as the governor gets up to speed. Then shift to 3rd, use the kickdown to get 3rd. direct, and then back off the throttle to engage 3rd. over. Five speeds! I used to do that with my 1951 Chrysler M-6 trans to use all four forwards. Jerry
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Isn't there a military 5 speed OD trans that bolts up to the same bellhousing as a Muncie or Saginaw transmission? Much heavier duty than a T5 and NOT the one that needs the SAE bellhousing. Jerry
| | | | | Joined: Nov 2016 Posts: 26 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 26 | Thank you. There's a guy in Parts Wanted who has one. I've asked him for some pics and I will look for the 7-bolt side cover. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Wrong trans- - - -that one has the non-synchronized 1st. gear. Jerry
