3 members (TUTS 59, Guitplayer, Otto Skorzeny), 34 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#1191151 11/16/2016 11:15 PM
Hi, Just got 1950 Chevrolet 1/2 ton. It looks like the engine was changed at some point. It has front side motor mounts that were welded to the frame.I searched for the numbers on the block and head and came up empty in the forums.Block# 0697170 F255ya and Head# 3835913 G
M 16 Also B33 913 241 570. These are all the numbers I found. Any help would be great! Thanks Steve
Steve1940 #1191154 11/16/2016 11:34 PM
The head number is for a 54/55.1 (before the "848" head came along)
Steve1940 #1191164 11/17/2016 1:03 AM
Your block is a 1955 Second Series
0697170 = unit number starting with 0001001
F = Flint Plant
255 = Second Series 1955
YA...you need to look at these letters again, could be XA, MA, DA, BA or PA.
Block Casting Numbers are found right above the oil pan on the front right side inside a concaved area. That number will help ID what you have...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Steve1940 #1191171 11/17/2016 1:31 AM
Steve1940 #1191172 11/17/2016 1:31 AM
Thanks for that info. I will look at those letters again. What does the letters XA mean? Thanks Steve
Steve1940 #1191174 11/17/2016 1:34 AM
We posted at the same time, Steve
At the link in my earlier post, you find that XA refers to 3600 (3/4 ton) with no drivetrain options.
Steve1940 #1191184 11/17/2016 2:07 AM
Thanks I missed that in your post. Maybe I need new glasses! Thanks again. Steve
