| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, Just got 1950 Chevrolet 1/2 ton. It looks like the engine was changed at some point. It has front side motor mounts that were welded to the frame.I searched for the numbers on the block and head and came up empty in the forums.Block# 0697170 F255ya and Head# 3835913 G M 16 Also B33 913 241 570. These are all the numbers I found. Any help would be great! Thanks Steve
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | The head number is for a 54/55.1 (before the "848" head came along) | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your block is a 1955 Second Series 0697170 = unit number starting with 0001001 F = Flint Plant 255 = Second Series 1955 YA...you need to look at these letters again, could be XA, MA, DA, BA or PA. Block Casting Numbers are found right above the oil pan on the front right side inside a concaved area. That number will help ID what you have... Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for that info. I will look at those letters again. What does the letters XA mean? Thanks Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | We posted at the same time, Steve
At the link in my earlier post, you find that XA refers to 3600 (3/4 ton) with no drivetrain options. | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks I missed that in your post. Maybe I need new glasses! Thanks again. Steve | | |
