| | | Forums66 Topics128,088 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | when replacing the front main seal on a 1954 235 we noticed right above/in between the two timing gears there was a crimped oil line. is this how it is meant to be or is it meant to be open to allow oil to lubricate the gears? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There should be a tube with a small hole in the side aimed at the gears. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | In my '38 216 there's a brass fitting screwed into the block with a small hole in it. Oil draining back from the rockers drips through it to lube the gears. I'm assuming the 235 is about the same.
| | | | | Joined: Oct 2011 Posts: 89 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 89 | we found the hole thankyou | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | It's apparently important since the service manual explains how to aim the discharge hole at the gear teeth. | | |
