2 members (RLB, Guitplayer),
139
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 5 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 5 | A google search is showing different sequences even when making sure the sequence is for a 283 not just SBC. Have 1960 C/N 3774682 heads. ?? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The specific sequence is not terribly important, just start in the middle and work toward both ends. I like to torque in about 3 steps- - - -40-50-65 ft/lbs. Lube the bolt threads and a dab under the bolt head with motor oil. Jerry
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Like HRL says, start in the middle and work outward, but do it side to side as you work your way outwards. Do one bolt on one side, then one bolt on opposite side and continue that way until you reach the ends. Do it in 3 steps.
1959 3100 Apache Fleetside
