0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | My '59 gas gauge reads Full all the time if the key is on. (Goes to E with the key off.) I tried disconnecting the wire at the top of the sending unit and it still reads full. I checked the connection under the cab (where it enters the harness with other wires) and that connection is good.
So...bad sending unit? It worked until recently, but it could have failed. Just don't want to spend money on another if there's something else I should check. That it reads Full with the wire disconnected makes me think it's electrical, but I don't understand how the thing works.
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That symptom indicates a bad (or, no) ground, usually from the sender to the body/frame. Try running a small ground wire from a sender-to-tank attachment post/bolt to a good ground (on the frame, or run a small ground lead back to battery ground). | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | I'm unclear. Should that ground wire run from that center post where the pick-up wire (sender unit to gauge) attaches? Or from one of the 6 small bolts that attach the sending unit to the tank? The former doesn't make sense...grounding the signal wire.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No - not the "pickup/sender/signal" wire - that wire is the "hot" lead to/from the gauge.
I think you have it figured out correctly: Ground one of the 6 small bolts that attach the sending unit to the tank. | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 |
