1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | My first post here. I got a great deal on a 50 gmc 100 and would like to upgrade the differential. I could get a 9" ford for cheap, but its 65" drum to drum. Slightly wide, i think. Has anyone put widened fenders on, or would it ruin the look? Thanks to everyone for a great site. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | You could always narrow the rear end, if you're set on the Ferd. | | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | I think I will keep looking for a narrower rear. $$$ for narrow job | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | From what others have posted, I think the early Chevy S-10 frames and drive trains are a good replacement for the originals. | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | From what others have posted, I think the early Chevy S-10 frames and drive trains are a good replacement for the originals. I just did a little research on this, and a rear axle from a 4x4 S10 is about a perfect fit as far as width. Very close to the tread (distance between tire tread centerlines on the axle) on a 47-55 Chevy. I saw one on our local craigslist for $250. Didn't look into the frame issue though.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2016 Posts: 17 New Guy | | New Guy Joined: Sep 2016 Posts: 17 | wow, a little late for an update , but i found an 82 camaro rear, put a posi in it , welded spring pads on, it works great | | |
