10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible), 40 guests, and 1 robot.
Topics128,036
Posts1,055,458
Members48,422
#118991 01/02/2006 8:33 PM
Apprentice
Apprentice
Oh Wise Ones,
I have another novice question. I recently removed the windsheild and there is rusted out areas along the seam. Is this a huge problem? Are there replacement parts? I have not seen any. Any sugestions? Thanks! JB
What have I gotten myself into?
58 Apache
65 C10
76 Silverado 4x4
03 2500 HD Duramax
http://s223.photobucket.com/albums/dd10/jbreen33/
#118992 01/02/2006 9:01 PM
no wise ones around here, just experienced grin
the pinch weld that makes up the windshield mount flange on the TF trucks is prone to corrosion over time from bad rubber seals - if it's not too bad [some of the depth of the flange left] and not extensive, just clean it up well, use some rust converter to stop any progression, a good rust proof primer/paint, and hope the rubber covers it - if it's really bad you'll hafta cut out some metal and replace it - there's no patch panels made for that area, but it's not toooo tough, just a bit of a PITA
#118993 01/03/2006 3:30 PM
Apprentice
Apprentice
Thanks Red!
This being my first attempt, I don't really know what to expect. Again thanks for the help.
58 Apache
65 C10
76 Silverado 4x4
03 2500 HD Duramax
#118994 01/03/2006 7:15 PM
Laroke detailed the process well, albeit on an AD:
http://www.laroke.com/larryk4674/2004/wip30.htm
