5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#1189293 11/03/2016 2:01 AM
I live in Prince Frederick Md, where can I pick up good epoxy primer any help?
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
BoToepfer #1189298 11/03/2016 2:17 AM
You can order from TCP Global. Their website isn't the best and may not show it but if you call they probably have it. I got some from them and also my local automotive paints supplier.
Dennis
40 Chevy 1/2 ton
BoToepfer #1189314 11/03/2016 3:37 AM
BoToepfer #1189339 11/03/2016 3:15 PM
Thanks, all ,
BoToepfer #1189349 11/03/2016 4:26 PM
You can't go wrong with SPI.
Give me ambiguity
or give me something else
BoToepfer #1189389 11/03/2016 11:04 PM
SPI all the way!
BoToepfer #1189998 11/07/2016 4:58 PM
can this material be applied by brush in areas that wont see daylight, ! or leaf springs?
BoToepfer #1190029 11/07/2016 7:46 PM
Insomniac
Insomniac
Originally Posted by BoToepfer
! or
Are you a programmer?
We brush on DP50 in places where it won't be seen. E.g Inside bed stake pockets. After making a batch up for spraying parts, there is some paint left over. We don't like wasting the stuff, so use it to cover small out of sight areas with a brush
Gord 🇨🇦
1954 1/2 ton 235 4 speed
BoToepfer #1190175 11/08/2016 6:17 PM
cool thanks,, ! Programmer?
BoToepfer #1190187 11/08/2016 7:41 PM
I've spayed rolled,and brushed SPI with great results.
The best part Is you can mix a batch and use it for 72hrs just keep it covered. Or
At 60hrs you can mix up more and add it to the first batch and start the clock all over.
Really handy for prepping and storing pieces.
3 coats are nearly indestructible.
You can't do that with ppg dpxx.
Give me ambiguity
